EFran7
7 years agoThe generation is stalled and I can only terminate the process by task manager. Does anyone know why and if there is a workaround about it? Thank you all.
Info: rio: exec C:/altera/12.1sp1/quartus/../ip/altera/common/ip_toolbench/v1.3.0/bin/ip_toolbench.exe -n {-devicefamily:Stratix IV} -lib_dir:C:/altera/12.1sp1/quartus/../ip/altera/rapidio/lib -flow_dir:C:/altera/12.1sp1/quartus/../ip/altera/common/ip_toolbench/v1.3.0/bin -wizard:rapidio -silent -parameterization.p_serial:1 -parameterization.p_xgmii:0 -parameterization.p_VOD:2 -parameterization.mode_selection:SERIAL_1X -parameterization.phy_selection:stratixivgx -parameterization.p_SYNC_ACKID:0 -parameterization.p_SEND_RESET_DEVICE:1 -parameterization.p_LINK_REQUEST_ATTEMPTS:7 -parameterization.p_data_rate:2500 -parameterization.p_ref_clk_freq:125 -parameterization.p_RXBUFRSIZE:4 -parameterization.p_TXBUFRSIZE:8 -parameterization.auto_cfg_rx:1 -parameterization.p_rx_threshold_0:20 -parameterization.p_rx_threshold_1:15 -parameterization.p_rx_threshold_2:10 -parameterization.p_TRANSPORT:1 -parameterization.p_TRANSPORT_LARGE:1 -parameterization.p_GENERIC_LOGICAL:0 -parameterization.p_PROMISCUOUS:1 -parameterization.rio_p_maintenance_master_slave:NONE -parameterization.p_MAINTENANCE_WINDOWS:1 -parameterization.p_TX_PORT_WRITE:0 -parameterization.p_RX_PORT_WRITE:0 -parameterization.rio_p_io_master_slave:AVALONMASTERSLAVE -parameterization.p_IO_SLAVE_WIDTH:29 -parameterization.p_READ_WRITE_ORDER:0 -parameterization.p_IO_MASTER_WINDOWS:1 -parameterization.p_IO_SLAVE_WINDOWS:1 -parameterization.p_DRBELL_TX:0 -parameterization.p_DRBELL_RX:0 -parameterization.p_DRBELL_WRITE_ORDER:0 -parameterization.p_DEVICE_ID:0x0 -parameterization.p_DEVICE_VENDOR_ID:0x0 -parameterization.p_DEVICE_REV:0xffffffff -parameterization.p_ASSEMBLY_ID:0x0 -parameterization.p_ASSEMBLY_VENDOR_ID:0x0 -parameterization.p_ASSEMBLY_REVISION:0x0 -parameterization.p_FIRST_EF_PTR:0x100 -parameterization.p_BRIDGE:0 -parameterization.p_MEMORY:1 -parameterization.p_PROCESSOR:0 -parameterization.p_SWITCH:0 -parameterization.p_PORT_TOTAL:1 -parameterization.p_PORT_NUMBER:0 -parameterization.p_SOURCE_OPERATION_DATA_MESSAGE:0 -parameterization.p_DESTINATION_OPERATION_DATA_MESSAGE:0 -parameterization.p_x4_mode:0 -parameterization.p_IO_MASTER:1 -parameterization.p_IO_SLAVE:1 -parameterization.p_MAINTENANCE:0 -parameterization.p_MAINTENANCE_MASTER:0 -parameterization.p_MAINTENANCE_SLAVE:0 -parameterization.p_ADAT:32 -parameterization.p_UNDER_SOPC:0 -parameterization.p_IO_SLAVE_OUTSTANDING_NREADS:16 -parameterization.p_IO_SLAVE_OUTSTANDING_NWRITE_RS:8 -simgen_enable.language:verilog -simgen_enable.enabled:0 -parameterization.p_UNDER_QSYS:1 C:/Users/Giacomo/AppData/Local/Temp/alt7981_5817592242511903221.dir/0001_rio_gen//QSYS_CORE_rio.vrio.vHi everyone,
I have a problem generating a qsys core.
I'm using the Quartus 12.1 SP1 suite and when I try to generate the QSYS core the environment goes stalled and stops on the line following.
- KennyT_altera
Hi, Can you upgrade your Quartus to the latest one Q18.1std? Usually this happend if you have an unsupported OS or all your device is not install in your computer. - KennyT_altera
still facing the issue?
