10 years agoThe difference between simulation and reality and warning (332060)
Hello, i am writing to you because i have some differences between simulation and reality. Before I start to write about warning mentioned above, I would like to tell about symptoms. I assign ...
10 years agoHello Lutzek,
You might consider:output out;
reg init;
reg counter;
assign init=6'd32;
assign out=init;
reg statePrev;
always @(posedge CLOCK_50)
begin
if (encoderInput!=statePrev)
begin
statePrev<=encoderInput;
counter<=counter+1;
end;
end;
Since encoder signals do not run on 50MHZ, but much slower, this can help. For performance reasons, the rest of your logic runs at clock speed, so there is not much added value introducing the encoder signal as a clock. Debouncing could be not necessary, you are not pressing a button, most encoders have electronics internally that prevent bouncing. Best Regards, Johi.
