14 years agoThe device was not created with a DEV_PART_ENUM
I'm kind of a new user of Altera's FPGAs. I'm trying to generate a Qsys system to run on an Intel Atom E6x5 which has a Altera FPGA Arria II GX, in particular it has the EP2AGXE6XXFPGA. I'm using Quartus II 11.0. What I did: I created a project according to the instructions in: IP Compiler for PCI Express: User Guide - chapter 17 I can create and simulate the project but when I come to the compilation stage Quartus gives an internal error (I'm attaching it below). If someone knows how to solve this or has a working example that could provide to me it would be very useful. Thanks, Frederico --------------------------------------------------------------------------------------------------------- Internal Error: Sub-system: DMGR, File: /quartus/ddb/dmgr/dmgr_utility_body.cpp, Line: 483 The device was not created with a DEV_PART_ENUM. Stack Trace: 0x1cb8e: DMGR_UTILITY_BODY::load_timing_info() + 0x4a (ddb_dmgr) 0x1cbd7: DMGR_UTILITY::load_timing_info() + 0x1d (ddb_dmgr) 0x1234a0: RBC_HSSI_UTIL::get_piranha_hssi_pcs_pma_effective_datarate_common(bool, CDB_CDR_PROTOCOL_HINT_ENUM, bool, bool, bool, unsigned int, bool, bool, _Dinkum_std::vector<_Dinkum_std::pair<BIG_TIME, BIG_TIME>, MEM_STL_ALLOCATOR<_Dinkum_std::pair<BIG_TIME, BIG_TIME> > >*) + 0xae (db_rbc) 0x1271e2: rbc_get_tgx_hssi_tx_pcs_pma_effective_datarate_tgx_hssi_config_legal_values + 0x408 (db_rbc) 0x7e1ff7: cal_rbc_tgx_hssi_tx_pcs_pma_effective_datarate_tgx_hssi_config(RBCGEN_FLOW_TYPE_ENUM, RBC_TGX_HSSI_TX_PCS_PMA_EFFECTIVE_DATARATE_TGX_HSSI_CONFIG_PARAM_STRUCT const&, RBC_TGX_HSSI_TX_PCS_PMA_EFFECTIVE_DATARATE_TGX_HSSI_CONFIG_ACF_STRUCT const&, RBC_TGX_HSSI_TX_PCS_PMA_EFFECTIVE_DATARATE_TGX_HSSI_CONFIG_PORT_STRUCT const&, RBC_TGX_HSSI_TX_PCS_PMA_EFFECTIVE_DATARATE_TGX_HSSI_CONFIG_INI_STRUCT const&, RBC_TGX_HSSI_TX_PCS_PMA_EFFECTIVE_DATARATE_TGX_HSSI_CONFIG_CPT_STRUCT const&, _Dinkum_std::vector<_Dinkum_std::pair<BIG_TIME, BIG_TIME>, MEM_STL_ALLOCATOR<_Dinkum_std::pair<BIG_TIME, BIG_TIME> > >*) + 0x10f (db_cal_generic) 0x951a10: cal_get_tgx_hssi_tx_pcs_pma_effective_datarate_tgx_hssi_config_legal_values + 0xbd8 (db_cal_generic) 0xb949ba: cal_is_tgx_hssi_tx_pcs_pma_effective_datarate_tgx_hssi_config_legal(RBCGEN_FLOW_TYPE_ENUM, CDB_ATOM_NODE*) + 0x1f8e (db_cal_generic) 0x16ec5de: cal_generic_is_atom_legal + 0x2a48 (db_cal_generic) 0xba5: cal_is_atom_legal + 0x63 (db_cal) 0x400337: CUT_ATOM_LEGALITY_IMPL::check_atom(CDB_ATOM_NODE*, RBCGEN_FLOW_TYPE_ENUM) + 0x397 (db_cut) 0x4b455e: cut_legality_check_atom_netlist(CMP_FACADE*, CDB_ATOM_NETLIST*, bool*, bool, bool) + 0x39e (db_cut) 0x79b77: AMERGE_MERGER_OP::perform_post_merge_operations() + 0x154b (atm_amerge) 0x7aed3: amerge_combine_netlist(CMP_FACADE*, bool, bool*) + 0x351 (atm_amerge) 0x7b249: amerge_mini_merge + 0x2b (atm_amerge) 0x2c218: QSYN_FRAMEWORK::do_mini_merge(CMP_FACADE*) + 0x3d8 (quartus_map) 0x2fc9f: QSYN_FRAMEWORK::write_qic_databases(bool) + 0xc7f (quartus_map) 0x301c5: QSYN_FRAMEWORK::write_databases(bool) + 0xf5 (quartus_map) 0x1211f: qexe_do_normal(QEXE_FRAMEWORK*, char const*) + 0x23b (comp_qexe) 0x19c6d: qexe_standard_main(QEXE_FRAMEWORK*, QEXE_OPTION_DEFINITION const**, int, char const**) + 0x437 (comp_qexe) 0x20f8b: qsyn_main(int, char const**) + 0x9b (quartus_map) 0x1ba98: msg_main_thread(void*) + 0x18 (ccl_msg) 0x58a8: thr_final_wrapper + 0xe (ccl_thr) 0x1d1e6: msg_thread_wrapper(void* (*)(void*), void*) + 0x72 (ccl_msg) 0x64100: mem_thread_wrapper(void* (*)(void*), void*) + 0xd0 (quartus_map) 0x9b20: err_thread_wrapper(void* (*)(void*), void*) + 0x2a (ccl_err) 0x58db: thr_thread_wrapper + 0x2f (ccl_thr) 0x2eec1: msg_exe_main(int, char const**, int (*)(int, char const**)) + 0x97 (ccl_msg) 0x1489f: main + 0x4f (quartus_map) 0x16c0e: __libc_start_main + 0xfe (c.so.6) End-trace Quartus II Version 11.0 Build 157 04/27/2011 SJ Full Version Service Pack Installed: 0.14
