RYang6
8 years agoTEMPERATURE SENSOR IP in STRATIX10 SX , READ INCORRECT VALUE
- JonWay_altera
- WGith
JwChin,
I logged on and I dont see any new messages in my personal message box.
FYI: My code reads the temperature correctly on my production 085 Stratix 10 part, but I still either get nothing for voltage or temperature data format for one of hte voltages.
I am going to try a voltage only design and see if I can get voltage working standalone on my production fpga.
- SZack
Jw - would you be able to call me when you get in so we can try and figure out why you are getting different results than Will? My number (856-520-0355) is on US east coast time which I think is 12 or 13 hours behind you. I'd be happy to talk before 11pm my time
- WGith
JwChin, I GOT IT WORKING! Both the voltage and Temperature IP at the same time. Here is what I did to get it working. 1. I used my state machine. 2. I used the S10Temp and VoltageSensor IP from YOUR project, not the ones I generated 3. No holding in reset was needed I had to modify the my code to use only 6 downto 0 for the S10Temp cmd_data signal, versus the newer 8 downto 0 as your IP is older I guess. So, this seems that I was right in that the IP generation is broken somehow. I don’t know what version you used, but for right now I will stick with it. Thank you for your patience, and hopefully you can relay back to the developers that there is something wrong in the IP generation for these blocks. --Will - JonWay_altera
