RYang6
8 years agoTEMPERATURE SENSOR IP in STRATIX10 SX , READ INCORRECT VALUE
JonWay_altera
7 years agoHi @SZack
No, I didn not use the Reset IP. I just run the design sent by Will as is. No modification done.
I only added some signals in signaltap, so that i can see the signals from the IP.
- SZack7 years ago
I'll check and see if Will is using an ES part on his board. That and try and use the TCL script design to confirm if the sensors are working on his part.
Did both the temperature and voltage both report values that made sense? In the screen shots you sent earlier it only showed the voltage IP response
