TEMPERATURE SENSOR IP in STRATIX10 SX , READ INCORRECT VALUE
Still having issues. I made sure to one enable one of the IP blocks at a time. I also have added very large waits between accesses. I have attached a zip file with my simple vhdl state machine that access the voltage and temperature IPs. I also included 4 signaltap screenshots which shows how I enable the voltage and temperature requests and how it shows the IP responding as expected, and then 2 screenshots which shows for the voltage IP it responds with 4 and not 5 requests and also the 2 requests that actually respond with data that is not zero is formatted in a way that is for temperature readings, not voltage readings. And then for the temperature IP response, I do get two responses, but the second response valid as you can see is 2 clock cycles too late for the second valid data response.
So, the temperature IP is almost working as expected, but the voltage IP is completely responding in a manner that makes no sense.
Note that I am running the IP blocks at 100 Mhz.
