RYang6
8 years agoTEMPERATURE SENSOR IP in STRATIX10 SX , READ INCORRECT VALUE
WGith
8 years agoHi,
Do I need to arbitrate between the Voltage IP and the Temperature IP blocks, meaning that only one of them can assert cmd_valid at a time, or does the IP blocks internally auto arbitrate?
I need to be able to find a combination of IP blocks that work so I can access both the voltage and temperature readings.
Any assistance you can provide in escalating this would be appreciated as there is definitely something not right with the current IP blocks.
