RYang6
8 years agoTEMPERATURE SENSOR IP in STRATIX10 SX , READ INCORRECT VALUE
JonWay_altera
8 years agoHi WGith,
Lets try this out:
1) can you use the exact design files in the youtube description. i want to Make sure we are on the same page and looking at the same design.
DOwnload the files and all the tcl scripts. Run it and see if you are getting the same results as shown in the youtube.
2) If you still see the sporadic problem, elaborate further what is the device P/N you are using. what quartus version are you using? how many boards tested & how many boards are seeing this problem? what is the expected temperature? how sporadic is the reading? does this happen to all channel or certain channels? can this be recovered by resetting the IP/ power cycling device?
I will more details in order to help you.
