11 years agoTCP/IP based remote signaltap on non-SoC device
Can I enable TCP/IP based remote signaltap on my device if I separately instantiate sld hub in the design? In my system there is a processor that talks to my device over an external bus. This processor runs the tcp/ip stack. My plan is to have this processor remove the tcp/ip headers and write the payload to the fpga. Logic inside the fpga will translate the incoming data to Avalon bus format and write to the sld hub. Is this the right way to go? My device is not an SoC device. Thank you. Best regards, SanjayNo RepliesBe the first to reply
