16 years ago
tco requirement inside design
Hi I'm trying to setup a tco requirement assignment between the clock and a multiplier output(not a pin). i was able to do it while there was a outputPin but now i need it between ff's. classic timing report says ignored due "no path found" or "no such node in netlist" or "synthesised away".
do i need additional assignments?
thanks in advance
    --- Quote Start ---
    thanks in advance
    --- Quote End ---
    why do you want to specify a tco for an internal signal ? When you set your clocks Quartus will take care about your internal tsu, tco ...
    Kind regards
    GPK
    i dont know if tco is the right assignment for this.
    i want to set the input-to-ouput delay between 6-9ns.
    --- Quote Start ---
    --- Quote End ---
    do you have a path between a FPGA input and FPGA output which contains only logic ?
    Kind regards
    GPK
