11 years ago
TCL scripting with PRE_FLOW_SCRIPT_FILE
Hi!
Including the following line in my QSF-File calls the TCL-Script before compilation to generate a timestamp form y FPGA.
set_global_assignment -name pre_flow_script_file "quartus_sh:compile_timestamp_make.tcl"
In addition to timestamp generation I have further things to do prior to compilation.
I want to extract the revision number from subversion.
Thus I wrote another TCL to do this and added another line to the QSF-File:
set_global_assignment -name pre_flow_script_file "quartus_sh:compile_svn_revision_make.tcl"
Unfortunately this does not work.
It seems to me that QuartusII can only handle one single TCL File with „PRE_FLOW_SCRIPT_FILE“
Is this correct or is there a way to handle multiple TCLs with „PRE_FLOW_SCRIPT_FILE“?
Thanks a lot for any help
mschultheis
    You could put all your code in one file or make a general preprocessing TCL file that calls other TCL files, e.g.:
    QSF:
    set_global_assignment -name PRE_FLOW_SCRIPT_FILE "quartus_sh:preprocessing.tcl"
    Contents of preprocessing.tcl:
    source compile_timestamp_make.tcl
    source compile_svn_revision_make.tcl
    The "source" keyword is a TCL command that evaluates another file as TCL code. See the tcl documentation (http://www.tcl.tk/man/tcl8.5/tclcmd/source.htm).
    Hope this helps!
    JBC
    yes this helps.
    It is an acceptable workaround.
    MSCHULTHEIS
