tcl in system mem editor
You may checkout the user guide here Intel Quartus Prime Pro Edition User Guide: Scripting
Look for these tcl commands in the attached image.
i try that didn't work. actually the above code are example from altera, i just modify a bit for my dev board device. does quartus tcl console accept command such as begin_memory_edit ? it always output quartus_stp error.
- RichardT_altera5 years ago
The error message indicate that you need to run the tcl script using the executable command:
quartus_stp
Usage:quartus_stp [-h | --help [=<option|topic>] |v ] quartus_stp <project name> [<option>] quartus_stp -t <script file> [<script args>] quartus_stp -s quartus_stp --tcl_eval <tcl command>Best Regards,
Richard Tan
p/s: If any answer from the community or Intel support are helpful, please feel free to give Kudos.- RichardT_altera5 years ago
If you type help in the tcl console, it will displays a complete list of available Intel® Quartus® Prime Tcl packages available in tcl console.
Unfortunately, you will found that the quartus_stp packages is not available in the tcl console so you can't use the insystem_memory_edit tcl script directly in tcl console. You may need to run it using command prompt.
Fyi, for best results, run shell commands and Intel® Quartus® Prime executables from a system command prompt outside of the Intel® Quartus® Prime software GUI.
Richard Tan
I believed that I have answered your question.
With that, I will now transition this thread to community support. If you have a new question, feel free to open a new thread to get the support from Intel experts. Otherwise, the community users will continue to help you on this thread. Thank you.
Richard Tan
