Altera_ForumHonored Contributor16 years agoTakes too long to get address I'm writing a simple program that reads and writes to RAM. If I want to write, I provide the starting address and a valid signal and I write to memory starting at that address until valid is deasser...Show More
Altera_ForumHonored Contributor16 years agoWhen you say register valid, does that mean, just assign it to a signal?
Recent DiscussionsMAX10 ADC - getting it to simulate in ModelsimFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verification
