15 years ago
SystemVerilog const definition issue manifested in quartus_map
I am running into an issue with a SystemVerilog constant defined in a package that manifests itself during quartus_map. It is very possible that I have misunderstood the SystemVerilog specification, but I have been able to simulate the design correctly. It is also possible that I have misunderstood what is supported in Quartus v11.0, but from what I can tell, everything requiring support for my particular case (packed arrays, const, packages, compilation unit) is supported.
Here are the messages I get during quartus_map:
Warning (10036): Verilog HDL or VHDL warning at my_example_pkg.sv(38): object "c_my_example_seeds" assigned a value but never read
Critical Warning: Net "work.my_example_pkg.c_my_example_seeds_*__*_" has a missing source. The net will be connected to GND and its default value will be ignored. ==> where * equals every element in my 2-D packed array.
Any ideas?
Here is the SystemVerilog HDL that results in the issue:
my_example_pkg.sv
`ifndef MY_EXAMPLE_PKG
`define MY_EXAMPLE_PKG
package my_example_pkg;
const logic [31:0][63:0] c_my_example_seeds = {
64'h0000_00ff_ffff_ffff,
64'heeee_eeee_0000_ee00,
64'h00dd_0000_dddd_dddd,
64'hcccc_cccc_cc00_0000,
64'h00bb_0000_bbbb_bbbb,
64'haaaa_aaaa_0000_aa00,
64'hf000_0000_0000_0000,
64'h0000_aaaa_aaaa_ffff,
64'h9999_0000_9999_9999,
64'h8888_0000_8888_8888,
64'h7777_7777_7777_0000,
64'h5555_6666_0000_0000,
64'h0000_1234_0000_0000,
64'h0000_0000_fedc_ba98,
64'h0000_0000_7654_3210,
64'h0123_4567_ffff_ffff,
64'heeee_eeee_89ab_cdef,
64'hf0f0_0f0f_dddd_dddd,
64'hcccc_cccc_e1e1_1e1e,
64'hd2d2_2d2d_bbbb_bbbb,
64'haaaa_aaaa_c3c3_3c3c,
64'hb4b4_4b4b_9999_9999,
64'h8888_8888_a5a5_5a5a,
64'h9696_6969_7777_7777,
64'h6666_6666_8787_7878,
64'h600d_c0de_5555_5555,
64'h4444_4444_0bad_0bad,
64'hdead_beef_3333_3333,
64'h2222_2222_0d06_f00d,
64'hface_fac7_1111_1111,
64'hba55_0000_ffff_ffff,
64'hffff_ffff_0000_fade
endpackage
import itoe_my_example_pkg::*;
`endif
my_example_design.sv
`include "utils_pkg.sv
`include "my_example_pkg.sv"
module my_example_design
// ports not shown
// only posting relevant code where constant c_my_example_seeds is used
genvar ref_i;
generate for (ref_i=0; ref_i<32; ref_i++) begin : g_ref_data_arr
always_ff @(negedge rstb or posedge clk)
begin
if (!rstb) ref_data_arr_reg[ref_i] <= c_my_example_seeds[ref_i];
else if (!cfg_en) ref_data_arr_reg[ref_i] <= c_my_example_seeds[ref_i];
else if ( (ref_i==id) & ready & valid)
ref_data_arr_reg[ref_i] <= lfsr64(ref_data_arr_reg[ref_i]); // lfsr64 defined in utils_pkg.sv
end
end endgenerate
endmodule
1 Reply
    To eliminate the issue, I moved the constant inside a function (still inside the package file) that I used to access individual elements in the seed constant. Instead of referring to the constant in my hdl, I referred to the function which returns the element of the constant array specified by the index input to the function.
    So, I have something that works now, but if anyone has any insight into why the original code shown above doesn't work, it would be helpful. I am trying to understand if my coding (a) violated SystemVerilog spec -- I don't think so..., (b) is not supported in Quartus 11, or (c) hit a corner case in Quartus.
