SystemVerilog Cast Syntax in Quartus 20.1
- 5 years ago
It appears that Quartus does not support SystemVerilog modports, and also is not planning on supporting VHDL 2019 interfaces which support view. Thus, any struct(SystemVerilog) or record(VHDL) must have all members as either in or out direction when using them on a portlist, that is my conclusion to all of this.
Yes, signed and unsigned types are part of SystemVerilog IEEE Standard 1800. Using a tool like Riviera-Pro for simulation, which is old (2018), the cast operator runs fine as I originally showed it working. Only in Quartus does it have an issue.
Looking closer at Quartus SystemVerilog support, it is not as thorough as anticipated. For example, Quartus does not support modports on interfaces in SystemVerilog. So I think you have to look at the detailed aspects of the language to see what is supported in Quartus.
