SOkte1
7 years agoSystem with 3 Flash Devices
In the board that we are developing, there are 3 Flash devices that are all MT25QU01G.
They have different purposes.
- Configuration Flash
- Nios II Boot Flash
- Logging Flash (Nonvolatile Data Storage)
Could you help me with Nios II connections, in the Platform Designer.
- GuaBin_N_Intel
Contributor
Looking at your system, all of QSPI controllers are well connected.Not really sure what your question is. - SOkte1
I am curious about CPU instruction master and data master connections to SPI avl_csr and avl_mem connections.
For logging Flash , I have not connected the Instruction Master since it is just a memory space for CPU.
For config Flash, I have connected both Instruction and Data Master.
For boot Flash, I have connected both Instruction and Data Master.
- GuaBin_N_Intel
Contributor
Yes, it's not needed to connect with inst master if you are not using it to run application code.
