8 years agoSystem Verilog Pin Assignment Issues
Newbie question - Just bought my first FPGA and working through examples to understand design and coding. My first example using a block diagram and .v file worked fine. My next try was using a book ...
8 years agoNot sure I understand the question. You select pin location assignments yourself. The code has nothing to do with it (unless you put pin assignments directly in your code using attributes). Can you explain a little more about what is going on?
