humandude
4 years agoSystem Verilog Concatenation
If I have an 8-bit register and I concatenate an input bit to itself excluding the MSB, what does the output look like? My assumption is that the value gets bit-shifted to the left (i.e the MSB gets ...
- 4 years ago
Yes, 100% correct. Same in Verilog or SystemVerilog.
VenT_Altera
4 years agoHi,
I have performed some compilation and simulation on the code in Modelsim. It verifies the discussion above. For the 2 bit-shifting to the right, zeros did fill in the upper two bits.
input [7:0] reg1;
input [1:0] input_bit;
output [7:0] out1, out2, out3, out4, out5;
output [8:0] out_shift;
//reg1 = 8'b10110010;
//input_bit = 1'b11;
assign out1 = {reg1 [6:0],input_bit [0]};
assign out2 = {reg1[7:0], input_bit};
assign out3 = {input_bit,reg1[7:0]};
assign out4 = {reg1, input_bit};
assign out5 = {input_bit,reg1};
assign out_shift = {input_bit[0], reg1}>>2;
Ven Ting
- VenT_Altera4 years ago
Attached with the screenshot of waveform simulation result.
