System Verilog Concatenation
- 4 years ago
Yes, 100% correct. Same in Verilog or SystemVerilog.
Both those examples are incorrect.
In the first, input_bit is still defined as a one bit register, so assigning 2'b11 to it actually results in a value of 1'b1.
So the result assigned to reg1 in the first case would be {8'b10110010,1'b1} truncated to the rightmost 8bits is 8'b01100101.
In the second case, the value {1'b1,8'b10110010} truncated to the rightmost 8bits is 8'b10110010.
When assigning a wider bitfield on the right hand side to a smaller width destination left hand side, the upper bits are truncated.
There is no implied shift, only truncation of the upper unused bits.
If you want a shift to occur, it must be explicit using the shift operator, like: {1'b1,8'b10110010}>>2 yields 7'b1101100.
I think you meant to define reg [1:0] input_bit , that would make more sense for your example.
Then:
reg [7:0] reg1 = 8'b10110010; reg [1:0] input_bit = 2'b11; reg1 <= {reg1[7:0], input_bit}; // reg1 <= {8'b10110010,2'b11} The new value of reg1 would be 8'b11001011. reg1 <= {input_bit,reg1[7:0]}; // reg1 <= {2'b11,8'b10110010} The new value of reg1 would be 8'b10110010 (unchanged, actually). Also: reg1 <= {reg1, input_bit}; // reg1 <= {8'b10110010,2'b11} The new value of reg1 would be 8'b11001011. reg1 <= {input_bit,reg1}; // reg1 <= {2'b11,8'b10110010} The new value of reg1 would be 8'b10110010 (unchanged, actually).
You're right, I forgot to update the bitfield when copy-pasting! The bit truncation makes sense. I do wonder about your comment regarding bit shifting:
" {1'b1,8'b10110010}>>2 yields 7'b1101100. "
The left hand side yields 9'b110110010, so shouldn't right-shifting yield 9'b001101100 (same size, shifted to the right with zeros filled in as the upper two bits)?
