Altera_ForumHonored Contributor15 years agosystem ID not found at target base address Hi. I'm new about quartus & nios.. I use quartus II, NIOS II 10.0 & Window7 32 & de2-70 fpga board. I have no problem until quartus pin assign, hdl compile&analysis&synthesis, programmer(...Show Moremultiple-attachments.zip479 KB
Recent DiscussionsHighlight similar instances of a selected word fails when scrollingSolvedAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]
