15 years ago --- Quote Start --- thanks for your apply. i did check the 2 options about system ID checks as you apply, but the attached image shows other problem.. please let me know other solution about this.. https://www.alteraforum.com/forum/attachment.php?attachmentid=2868 --- Quote End --- i want to known that when you add the system id component ,does the system id show zero
