15 years ago --- Quote Start --- You need to either: 1) add a system ID component to your SOPC system 2) disable the system ID check (check both boxes in the "System ID Checks" area shown in your second screen shot) --- Quote End --- thanks for your apply. i did check the 2 options about system ID checks as you apply, but the attached image shows other problem.. please let me know other solution about this.. https://www.alteraforum.com/forum/attachment.php?attachmentid=2868
