16 years ago --- Quote Start --- Hi all, I'm using the quartus tools under Linux (Fedora). Every thing was OK (Fedora 11) until I have upgraded to Fedora 12 and wanted to perform new synthesis. When I use sopc builder in my design and want to generate the SoPC system, I have now the following errors:
Info: Starting PTF file elaboration.
"/opt/altera9.0/quartus/linux/jre/bin/java" -Xmx512M -classpath "/opt/altera9.0/quartus/sopc_builder/bin/sopc_builder.jar:/opt/altera9.0/quartus/sopc_builder/bin/PinAssigner.jar:/opt/altera9.0/quartus/sopc_builder/bin/sopc_wizard.jar:/opt/altera9.0/quartus/sopc_builder/bin/jptf.jar" sopc_builder.sopc_builder -d"/opt/altera9.0/quartus/sopc_builder" -notalkback=1 -projectnamestandard.qpf -projectpath/home/kadionik/design/design --no_splash --refresh /home/kadionik/design/design/std_1s10.vhd --quartus_dir="/opt/altera9.0/quartus" --sopc_perl="/opt/altera9.0/quartus/linux/perl" --sopc_lib_path="/home/kadionik/design/design+/opt/altera9.0/ip/altera/asi/lib/ip_toolbench+... /triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet++/opt/altera9.0/quartus/../ip/altera/sopc_builder_ip+/opt/altera9.0/quartus/../ip/altera/nios2_ip"
/opt/altera9.0/quartus/linux/jre/bin/java: symbol lookup error: /usr/lib/libXi.so.6: undefined symbol: XESetWireToEventCookie
Error: Failed to refresh PTF file
Info: Finished elaborating PTF file.
Executing: /opt/altera9.0/quartus//sopc_builder/bin/sopc_builder --classic --generate /home/kadionik/design/design/std_1s10.ptf
Info: Starting generation...
"/opt/altera9.0/quartus/linux/jre/bin/java" -Xmx512M -classpath "/opt/altera9.0/quartus/sopc_builder/bin/sopc_builder.jar:/opt/altera9.0/quartus/sopc_builder/bin/PinAssigner.jar:/opt/altera9.0/quartus/sopc_builder/bin/sopc_wizard.jar:/opt/altera9.0/quartus/sopc_builder/bin/jptf.jar" sopc_builder.sopc_builder -d"/opt/altera9.0/quartus/sopc_builder" -notalkback=1 -projectnamestandard.qpf -projectpath/home/kadionik/design/design --generate /home/kadionik/design/design/std_1s10.vhd --quartus_dir="/opt/altera9.0/quartus" --sopc_perl="/opt/altera9.0/quartus/linux/perl" --sopc_lib_path="/home/kadionik/design/design+/opt/altera9.0/ip/altera/asi/lib/ip_toolbench+/opt/altera9.0/quartus/common/librarian/factories+/opt/altera9.0/quartus/cusp/bin+... ... /triple_speed_ethernet/lib/sopc_builder/altera_triple_speed_ethernet++/opt/altera9.0/quartus/../ip/altera/sopc_builder_ip+/opt/altera9.0/quartus/../ip/altera/nios2_ip"
Error: System generation failed.I have no system generation now. The strange thing is that is OK when I perform it in command line:
I don't know why it doesn't work now under the sopc builder GUI... Problem with java environment? Problem with /usr/lib/libXi.so.6 (XESetWireToEventCookie undefined) ? No, I've recompiled the library (not stripped) and the symbol is present... I've installed quartus 9.1 too and I have the same problem... Any idea? Thank You; Patrice --- Quote End --- I've got the same problem with ubuntu 9.04 and altera 9.1 . I don't know if it is a perl or a java problem ? any solution ? reese
