13 years agoIt is a bad idea to disable the ignore sys id and ignore timestamp options. If you have an error with those options enabled it means that you have an inconsitency in your project, that your compiled software and uploaded FPGA image are based on different definitions.
Try to recompile everything (hardware and software) and be sure that you are uploading the correct .sof FPGA image and software.
