rtalluri
5 years agoSystem_Console.exe - [USB MASTER] master_read_to_file: java.lang.Exception:
We have Custom HW where maximum of the design is leveraged from Max-10 Dev Kit Rev C.
Here we are using the System-Console - USB Direct interface as a Master to Transfer a file or readback to file...
YuanLi_S_Intel
4 years agoThanks for the clarification. Usually this issue is due to hardware connection or the device readiness to receive command from system console. Can you try to add some delay or read status register after each command?
