11 years ago --- Quote Start --- If you don't need digit accuracy, you could use a quadruple-precision floating point number. Those are good up to 10^4962. But the maximum integer that can be stored without loosing accuracy is 2^113. --- Quote End --- Hello, Thank you so much for your response :). Could you please elaborate more on this? I think we can compromise a little bit of accuracy. Thanks!
