LFahem
8 years agoSynthesis problem when instanciating different GXB tranceivers
Hi, I am making a design that uses Triple Speed Ethernet. My design contains different instances of this IP and I want to define a partition for each TSE instance. However when trying this, Quartus ...
- 8 years ago
Apparently, Incremental Compilation can not be done with particular IPs. Actually, hardware IPs like lvds and hps, sould be assigned to the root partition.
Best regards.
AnandRaj_S_Intel
8 years agoHi,
I have just used setting mentioned in previous posts but not succeeded in reproducing the scenario or error.
Can you share the project file?
I was able to successfully compile the project attached image for reference.
Anand Raj Shankar
