LFahem
8 years agoSynthesis problem when instanciating different GXB tranceivers
Hi, I am making a design that uses Triple Speed Ethernet. My design contains different instances of this IP and I want to define a partition for each TSE instance. However when trying this, Quartus ...
- 8 years ago
Apparently, Incremental Compilation can not be done with particular IPs. Actually, hardware IPs like lvds and hps, sould be assigned to the root partition.
Best regards.
LFahem
8 years agoHi,
Thank you for answering my question. Actually, I made an entity that contains a Triple Speed Ethernet, an FPLL and a Phy Reset Controller. Then I createde a top level design with two instances of this entity. According to th quartus error messages, I think that the problem is coming from the FPLL and the Phy Reset Controller. I have uploaded the bloc design and the quartue error message.
Best regards.
