Swetha_A
4 years agoSynthesis: Place and route failure for Arria device in Debian 11 platform
The following error is caught for all the features for Arria device during Place and route for 20.1.1 version of Altera.
[0m[0;31mError (293007): Current module quartus_fit ended unexpectedly. ...
- 4 years ago
The issue was not reproducible using machines with higher RAM memory but the issue got fixed after updating the swap space to non-zero in 10 GB RAM debian 11 machines. The place and route was failing due to zero swap space in debian 11 machines.
It has taken time for us to debug and identify the actual cause.
Thank you for the patience!
ShengN_altera
4 years agoSince I had provided you the solution and did not received any feedback from you, I shall set this case to close pending. If you still need further assistance, you are welcome reopen this case within 20days or open a new case, some one will be right with you.
