Synthesis: Place and route failure for Arria device in Debian 11 platform
- 4 years ago
The issue was not reproducible using machines with higher RAM memory but the issue got fixed after updating the swap space to non-zero in 10 GB RAM debian 11 machines. The place and route was failing due to zero swap space in debian 11 machines.
It has taken time for us to debug and identify the actual cause.
Thank you for the patience!
If like that you may have to increase the memory RAM or reduce the design size. Place and route usually consumes more RAM during compilation.
Sheng
- Swetha_A4 years ago
- ShengN_altera4 years ago
Just know about there is such feature for extra RAM space. Great to know that. Thanks for your genuine sharing. May be you can mark it as solution for better future reference.
