Swetha_A
4 years agoSynthesis: Place and route failure for Arria device in Debian 11 platform
The following error is caught for all the features for Arria device during Place and route for 20.1.1 version of Altera.
[0m[0;31mError (293007): Current module quartus_fit ended unexpectedly. ...
- 4 years ago
The issue was not reproducible using machines with higher RAM memory but the issue got fixed after updating the swap space to non-zero in 10 GB RAM debian 11 machines. The place and route was failing due to zero swap space in debian 11 machines.
It has taken time for us to debug and identify the actual cause.
Thank you for the patience!
Swetha_A
4 years agoThank you sir,
The problem persists even after deleting db and db_incremental folders.
I'm debugging the issue more and will acknowledge once I get any solution.
