9 years agoSynthesis output for multiple driver within one always
Hi, I came across a code snippet and has been boggling my mind quite a bit. The equivalent to the code is below: a is output and x is an internal register always@(posedge clk) begin ...
9 years agoRe-writing the code with comments might help you understand this ..
always @(posedge clk or posedge rst) begin
if (rst) begin
// Reset values
a <= 1'b0;
b <= 1'b1;
end
else if (x == 1) begin
// Defaults
a <= 1'b0;
b <= 1'b1;
// Over-rides
if (x) begin
a <= ~a;
end
if (~y) begin
b <= 1;
end
end
end
This style of code can is useful in the combinatorial process of an FSM, as you can ensure that all outputs have assignments. The synthesis tool infers that the "last assignment" to the output is the winner and generates the combinatorial logic feeding the register accordingly. Cheers, Dave
