12 years agoThe two blocks of code are functionally equivalent. Verilog simulation and synthesis tools allow multiple NBA assignments to the same variable in the same process - the last write cancels the previous writes.
The writing style of the first block is convenient when a process contains many variable assignments and many branching statements. Each branch need only specify the NBA assignments that are different from the default.
