Synthesis Hung for Large Designs
I have ask the engineering to check on this abnormal behavior. Will let you know once there is update.
So you were able to recreate the issue, correct?
- RichardT_altera5 years ago
Yes, I am able to duplicate the issue with Quartus stuck at 33% Analysis & Synthesis stage.
You mentioned previously that you are able to implement design with
16x16x16x128 Single-Port RAM
16x16x16x32 Single-Port ROM
16x16x16x64 Two-Port RAM
and32x32x32x128 Single-Port RAM
32x32x32x32 Single-Port ROM
32x32x32x64 Two-Port RAMCould you help to share the .qar design files that is able to pass the Analysis and Synthesis? Either 32 or 16 will do.
Do you have the .qar design for 64x64x64 as well ? Engineering need it instead of the design files zip. I am not able to achieve the project as the Quartus keep crashing. Not sure is it the same case for you.
