Synthesis Hung for Large Designs
Yes I have tried on multiple machines each with their own installation of Quartus Pro 20.4. I even tried earlier version of Quartus Pro and git the same issue. I only update to Quartus Pro 20.4 to prevent the request to run with the latest version of the tool
Could you help to share your design so I could test it from my side?
- apducimo5 years ago
Working on it. I am trying to reproduce a logfile to accompany the design inputs.
I have attached all necessary design files and the output files resultant of running synthesis.
The output files were generated using Quartus 18.1, with synthesis stuck at 33% after 11 hours. I will let it go until my allotted 72 hours have expired on the machine this process in running on.
Though these reports are generated with 18.1, you should be able to reproduce the issue with 20.4.
Let me know if you run into any issue trying to retrace this issue on your end or if you need any other files from the Quartus run.
I have updated logs but I the sizes of files exceed the attachment limitation. Let me know how to transmit the updated reports.
