synthesis have a wrong result when some logic in generate block
thanks for relay. do you mean, I need try to add a large code commented block (100 lines or more) before the generate block and after the generate block?
the commented block may like below:
hi Wsiwe, yes that what I observed, took some code, not garbage, copy paste then comment out. generally I leave between code I rewrote and at end when change apply'd to new code.
I am trying on Linux took 1 minute to build, when I am sure or close to of what trigger this I can try on other platform.
One time I try'd leave compiling on Win7, same behavior, but appear and disappear in a while.
I am also parallel installing last Ubuntu version to avoid comment from Intel clerks and close the loop to culprit of.
Good answer to this was to change vendor, I am too close to deadline.
My Hardware is intended controlling a mechanical with huge moving part and cannot risk the life of none. This is not a game.
Robert
