Synthesis error while getting parameters from interface
I'm trying to synthesis code where based on parameters from interface I create structure and the once again I take interface parameters. Such a case results with error:
Error(13433): Verilog HDL Defparam Statement error at top.sv(34): value for parameter "WIDTH_2" must be constant expression
I check the code in Vivado and Questa and it works well.
Please find attached source code and log from quartus.
Steps to replicate:
- Use `Quartus Prime Pro Edition 22.2.0` with any devices installed
- Create a new project, add following code to `top.sv` file.
- Set `top` as Top-level Entity
- Run `Analysis & Synthesis`
Update from Engineering Team: The issue is planned to fix in the Quartus future release version 23.1.
Ven Ting
- VenT_Altera
Ven Ting
- ShengN_altera
Internal latest feedback:
This issue got fixed by Verific in Aug-22 release. Yet to integrate this Verific release into Quartus.
Now, asking internal team for any workaround or patch released for this issue. Please allow some working time.
Sheng
- VenT_Altera
Thanks for attaching the file. I will check this with the Engineering Team. It might take some time to debug the issue, please stay tuned.
Ven Ting
- VenT_Altera
FYI, Engineering Team requires some time to investigate further to the error. Kindly stay tuned with us.
Ven Ting
- PiotrWija
Thank you for an update.
Piotr Wija
- PiotrWija
thank you for the update. I do not need any workaround. I will wait for Quartus 23.1.
Piotr Wija
