12 years ago
Syntax to conditionally assign integer or parameter
Appreciate any help on how to assign an integer or parameter based on a signal, I know the following isn't correct, but i think you can see what I am trying to accomplish. RATE is latter used in an equation with other parameters. Does RATE have to be a parameter for the equation to work?
wire low;
RATE = low ? 3 : 4;
if(BCK_DIV >= REF_CLK/(RATE*DATA_WIDTH*CHANNEL_NUM*2)-1 )
1 Reply
    I got it figured out -
    integer SAMPLE_RATE;
    always @(*)
    SAMPLE_RATE <= toneSelect ? 68000 : 48000;
