basically you have to stop your sequence state machine for a while
case r is
when "0111" =>
r <= "1011";
when "1011" =>
r <= "1101";
when "1101" =>
r <= "1110";
when "1110" =>
r <= "0111";
when others =>
null;
end case;
I would embed the delay counter directly to the state maschine, but that's a matter of taste.
CASE state IS
WHEN S1 =>
timer <= conv_unsigned(10,4);
WHEN S_WAIT =>
IF timer = 0 THEN
state <= S_UP;
ELSE
timer <= timer - 1;
END IF;
WHEN S_UP =>
Basically I would use named states rather than defining state variable coding myself. Did you notice, that Quartus has a template function in HDL editor context menu? It also includes FSM examples with usual VHDL syntax.
Frank
