12 years agoThanks, but new errors have appeared
# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# Refreshing D:/tdc/simulation/qsim/work.freq_dev# Loading work.freq_dev# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-3033) freq.vo(66): Instantiation of 'cycloneiii_io_obuf' failed. The design unit was not found.# # Region: /freq_dev_vlg_vec_tst/i1# Searched libraries:# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# D:/tdc/simulation/qsim/work# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-3033) freq.vo(76): Instantiation of 'cycloneiii_io_ibuf' failed. The design unit was not found.# # Region: /freq_dev_vlg_vec_tst/i1# Searched libraries:# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# D:/tdc/simulation/qsim/work# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-3033) freq.vo(93): Instantiation of 'cycloneiii_lcell_comb' failed. The design unit was not found.# # Region: /freq_dev_vlg_vec_tst/i1# Searched libraries:# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# D:/tdc/simulation/qsim/work# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-3033) freq.vo(112): Instantiation of 'dffeas' failed. The design unit was not found.# # Region: /freq_dev_vlg_vec_tst/i1# Searched libraries:# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# D:/tdc/simulation/qsim/work# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# Refreshing D:/tdc/simulation/qsim/work.freq_dev_vlg_sample_tst# Loading work.freq_dev_vlg_sample_tst# ** Error: (vsim-19) Failed to access library 'cycloneiii_ver' at "cycloneiii_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_ver' at "altera_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'altera_mf_ver' at "altera_mf_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library '220model_ver' at "220model_ver".# # No such file or directory. (errno = ENOENT)# ** Error: (vsim-19) Failed to access library 'sgate' at "sgate".# # No such file or directory. (errno = ENOENT)# Refreshing D:/tdc/simulation/qsim/work.freq_dev_vlg_check_tst# Loading work.freq_dev_vlg_check_tst# Error loading design
Error. I've found similar error here (http://www.altera.us/support/kdb/solutions/rd06172013_886.html), but there is no \modelsim_ase\modelsim.ini.
