17 years ago --- Quote Start --- Did you check whether the Quartus device migration feature will let you select both packages at the same time? If you use that feature, Quartus will compile using a pin-out that works in both packages. --- Quote End --- I wondered about that, I'll give it a try. Thanks Ian
