11 years agoSupport Vector Machine VHDL
I would like to know if there someone has a VHDL code for Support Vector Machine. I would also like to know if someone could explain to me this line of code res: out sfixed(7 downto -10)...
10 years ago --- Quote Start --- Please Sir, I need your help in making me understand this line use ieee.fixed_pkg.all when I ran the program, I found this problem ERROR:HDLParsers:3014 - "C:/Users/George1/Desktop/fixed_top.vhd" Line 4. Library unit fixed_pkg is not available in library ieee. I need the library please. Thank you so much --- Quote End --- How are you trying to compile the code? the fixed_pkg is part of the VHDL 2008 standard and is included with modelsim. For Quartus prime 15.1 and later, the package is included. For earlier versions, you need to find a version of the library from somewhere.
