11 years agoSupport Vector Machine VHDL
I would like to know if there someone has a VHDL code for Support Vector Machine. I would also like to know if someone could explain to me this line of code res: out sfixed(7 downto -10)...
10 years ago --- Quote Start --- I would like to know if there someone has a VHDL code for Support Vector Machine. I would also like to know if someone could explain to me this line of code res: out sfixed(7 downto -10) I know what is downto, but I have never seen it to a negative number before. Does that mean this is sfixed is 17 bits? If so why not 16 downto 0 Thanks I also attached an SVM code that I understand but having trouble some parts. --- Quote End --- Please Sir, I need your help in making me understand this line use ieee.fixed_pkg.all when I ran the program, I found this problem ERROR:HDLParsers:3014 - "C:/Users/George1/Desktop/fixed_top.vhd" Line 4. Library unit fixed_pkg is not available in library ieee. I need the library please. Thank you so much
