shreyas
7 years agoStuck at the Analysis and synthesis stage
Hi all, I am trying to synthesize a design which is relatively big with ~ 30k lines of RTL. But the process just get stuck at analysis and synthesis stage. I waited for more than 10 hours but had no...
GuaBin_N_Intel
Contributor
7 years agoHow much compile time does it take if it can pass through? Can you share out the passing Fitter report to check the resource utilization in term of ALM and memory block? I suspect it may be running out of resource or congestion in some location.
shreyas
7 years agoHi
Thanks for replying.
It was taking 4-5 hours to go till sign-off. I think resource utilization is not a problem, resource utilization was 18% for ALM's and 5% of BRAM. I have attached the reports for your reference. Also, design completed the synthesis after waiting for 2 days. I attached reports of both working and problematic designs.
Thank you
