11 years agoStratixV transceiver simulation
I am simulating a simple StratixV HSSI transceiver set up in BASIC mode with 20-bit parallel data interfaces at 300 MHz. In the test bench the TX serial output is connected to the RX serial input. ...
11 years ago --- Quote Start --- There are only five files inside of altera_ttk_examples_arria_v_gz.zip - assuming this is the example you are referring to. I would need all the RTL for the qsys_system module that is instantiated within ttk_example.vhd and qsys_system_tb.sv in order to run a simulation. The qsys_system_tb.do file only sets up the wave window - it does not compile the RTL or kick off vsim. Is there another ZIP file I should be looking at? --- Quote End --- Yeah, there is something screwy with the zip file. It has the files needed if you walk-through the document, but its missing the synthesis script that automates everything. I'll have to look at it tomorrow. I received your zip file, I'll take a look at it tomorrow too. Cheers, Dave
