11 years agoStratixV transceiver simulation
I am simulating a simple StratixV HSSI transceiver set up in BASIC mode with 20-bit parallel data interfaces at 300 MHz. In the test bench the TX serial output is connected to the RX serial input. ...
11 years agoI have stripped the project down into a 32M ZIP file. The only reason it is so big is because I included the Altera libraries for ModelSim that are created by the msim_setup.tcl script. I can remove these for those who already have their ModelSim environment set up with the StratixV libraries.
The simulation can be run with a few mouse clicks. I have a script which builds the IP libraries, compiles everything else, kicks off vsim and opens the Wave window. Double-clock on the MPF to open ModelSim. Tools->TCL->Execute Macro and select s5_xcvr_test_tb.do. The Quartus project is included as well. A double-click to open Quartus and another click to compile the project. I uploaded an attachment named StratixVGX_XCVR_Test.zip but I have no idea where it ended up or how anyone would download it. Maybe that Manage Attachments button down below does both upload and download.
