The easiest/fastest way without thinking too much about it is to simply create a blank project and set your MegaWizard file as the top level entity and compile it.
Review the Fitter reports to see how many M9K it used. - Altera_Forum
--- Quote Start --- The easiest/fastest way without thinking too much about it is to simply create a blank project and set your MegaWizard file as the top level entity and compile it. Review the Fitter reports to see how many M9K it used. --- Quote End --- Thanks. Indeed, It can be seen that the Quartus uses two units of M9K to provide a "three-port" RAM unit with two Read-Inputs. Thank you very much. Lior.
