12 years agoStratix IV GX - ALTPLL in VHDL
Hi!
Devide used: Stratix IV, EP4SGX180KF40C02N Software used: Quartus II, 13.0.1.232; also tried compiling with v12 and v9. I am trying to get a simple PLL frequency multiplier running in VHDL using the megafunction "altpll", which generates 320MHz out of 40MHz: --------------------------------------------------------- Begin of Code library ieee; use ieee.std_logic_1164.all; use ieee.numeric_std.all; library altera_mf; use altera_mf.altera_mf_components.all; entity test_stratix_pll is port ( clk0_in : in std_logic -- 40MHz ); end; architecture BEHAVIOR of test_stratix_pll is signal clock : std_logic := '0'; -- 40MHz signal highspeed_serial_tx_clock_320MHz : std_logic := '0'; signal highspeed_serial_tx_clock_320MHz_all : std_logic_vector (9 downto 0); begin Clock <= clk0_in; highspeed_serial_tx_clock_320MHz_generator : altpll -- generates 320MHz from the 40MHz-Clock. generic map ( intended_device_family => "Stratix IV", clk0_multiply_by => 8, clk0_divide_by => 1, inclk0_input_frequency => 25000, inclk1_input_frequency => 25000, operation_mode => "normal", width_clock => 10 ) port map ( --clk(0) => highspeed_serial_tx_clock_320MHz, clk => highspeed_serial_tx_clock_320MHz_all, inclk(0) => clock, inclk(1) => clock ); end BEHAVIOR; ----------------------------------------------------------- End of Code With a Cyclone II using the following code for the altpll in the otherwise identical VHDL it worked immediately as intended, verified per oscilloscope: --------------------------------------------------------- Begin of Code highspeed_serial_tx_clock_320MHz_generator : altpll -- generates 320MHz from the 40MHz-Clock. generic map ( clk0_multiply_by => 8, clk0_divide_by => 1, inclk0_input_frequency => 25000, inclk1_input_frequency => 25000, operation_mode => "normal" ) port map ( clk(0) => highspeed_serial_tx_clock_320MHz, inclk(0) => clock ); ----------------------------------------------------------- End of Code But with the Stratix i get the huge list of error messages shown at the attached file quartus-error-messages.txt ... I also tried all the parameters the MegaWizard gave me, and most of these described in the altpll-documentation, and a lot of variations of it (i spent about 2 days with it....), with or without reset lines and so - no change... for example: --------------------------------------------------------- Begin of Code GENERIC MAP ( bandwidth_type => "AUTO", clk0_divide_by => 1, clk0_duty_cycle => 50, clk0_multiply_by => 8, clk0_phase_shift => "0", compensate_clock => "CLK0", inclk0_input_frequency => 25000, intended_device_family => "Stratix IV", lpm_hint => "CBX_MODULE_PREFIX=bla", lpm_type => "altpll", operation_mode => "NORMAL", pll_type => "AUTO", port_activeclock => "PORT_UNUSED", port_areset => "PORT_USED", port_clkbad0 => "PORT_UNUSED", port_clkbad1 => "PORT_UNUSED", port_clkloss => "PORT_UNUSED", port_clkswitch => "PORT_UNUSED", port_configupdate => "PORT_UNUSED", port_fbin => "PORT_UNUSED", port_fbout => "PORT_UNUSED", port_inclk0 => "PORT_USED", port_inclk1 => "PORT_UNUSED", port_locked => "PORT_UNUSED", port_pfdena => "PORT_UNUSED", port_phasecounterselect => "PORT_UNUSED", port_phasedone => "PORT_UNUSED", port_phasestep => "PORT_UNUSED", port_phaseupdown => "PORT_UNUSED", port_pllena => "PORT_UNUSED", port_scanaclr => "PORT_UNUSED", port_scanclk => "PORT_UNUSED", port_scanclkena => "PORT_UNUSED", port_scandata => "PORT_UNUSED", port_scandataout => "PORT_UNUSED", port_scandone => "PORT_UNUSED", port_scanread => "PORT_UNUSED", port_scanwrite => "PORT_UNUSED", port_clk0 => "PORT_USED", port_clk1 => "PORT_UNUSED", port_clk2 => "PORT_UNUSED", port_clk3 => "PORT_UNUSED", port_clk4 => "PORT_UNUSED", port_clk5 => "PORT_UNUSED", port_clk6 => "PORT_UNUSED", port_clk7 => "PORT_UNUSED", port_clk8 => "PORT_UNUSED", port_clk9 => "PORT_UNUSED", port_clkena0 => "PORT_UNUSED", port_clkena1 => "PORT_UNUSED", port_clkena2 => "PORT_UNUSED", port_clkena3 => "PORT_UNUSED", port_clkena4 => "PORT_UNUSED", port_clkena5 => "PORT_UNUSED", using_fbmimicbidir_port => "OFF", width_clock => 10 ) ----------------------------------------------------------- End of Code I would be very grateful for any hint what i can do to get the PLL running. Thanks in advance, best regards :-)
