14 years agoIt's 9bit on write side and 36bit on read side:
component ts_fifo1
PORT (
aclr : IN STD_LOGIC := '0';
data : IN STD_LOGIC_VECTOR(8 DOWNTO 0);
rdclk : IN STD_LOGIC;
rdreq : IN STD_LOGIC;
wrclk : IN STD_LOGIC;
wrreq : IN STD_LOGIC;
q : OUT STD_LOGIC_VECTOR(35 DOWNTO 0);
rdempty : OUT STD_LOGIC;
rdusedw : OUT STD_LOGIC_VECTOR(10 DOWNTO 0));
end component;
wrclk = 135MHz wrreq goes high every 5 clock edges rdclk = 125MHz rdreq goes high, when rdusedw'high = '1'; FIFO parameters:
PARAMETERS
ACF_DISABLE_MLAB_RAM_USE = "FALSE",
ADD_RAM_OUTPUT_REGISTER = "OFF",
ADD_USEDW_MSB_BIT = "OFF",
CLOCKS_ARE_SYNCHRONIZED = "FALSE",
DELAY_RDUSEDW = 1,
DELAY_WRUSEDW = 1,
LPM_NUMWORDS,
LPM_SHOWAHEAD = "OFF",
LPM_WIDTH,
LPM_WIDTH_R = 0,
LPM_WIDTHU = 1,
LPM_WIDTHU_R = 1,
MAXIMIZE_SPEED = 5,
OVERFLOW_CHECKING = "ON",
RAM_BLOCK_TYPE = "AUTO",
RDSYNC_DELAYPIPE = 5,
READ_ACLR_SYNCH = "OFF",
UNDERFLOW_CHECKING = "ON",
USE_EAB = "ON",
WRITE_ACLR_SYNCH = "OFF",
WRSYNC_DELAYPIPE = 5,
CBXI_PARAMETER = "NOTHING"
