14 years ago --- Quote Start --- Basically, the synthesisor does what should be best for your design. overruling the synthesisor can be hard work. --- Quote End --- This is obviously true in arithmetic operations. But as I found out in Cyclone III tests, the synthesis tool doesn't take full advantage of arithmetic mode for non-arithmetic problems, e.g. by utilizing the carry chain. I guess, this may be also the case with Stratix ALM. See: http://www.alteraforum.com/forum/showthread.php?t=27881
